After a good few years with silver and "champagne" kit, I put this stuff together last summer. Haven't changed much apart from wires since which is maybe a good sign.
Top down:
Denon TU-1500RD
Freeview HD recorder - CA640p
Brinkmann Integrated
Merlin BAM - PSU for phono stage
Telly
Toshiba SD-9500e
Nakamichi CR-7
Electrocompaniet ECD-1
Speakers are Merlin VSM-MM perched on some granite
Headphones are Sennheiser HD-600s with Cardas wire
Wires are Virtual Dynamics, KAS Audio, Zanash, Cardas, Audience, Shunyata, PS Audio
The rack is an Ugli from IKEA and is as far as I'm going towards yer traditional angle-iron scaffolding
You may notice that I list a phono stage but no TT? Well, there is a freshly fettled LP12/LVII/103 (inherited, before all you gobshites start up with your noise ) in the cupboard with a wall shelf but the only free wall near the kit isn't flat enough or strong enough to take it and this is a rented place... The 'dek does get wheeled out and plopped on a table for occasional use but the floor is bouncy and there are kids and a cat about.
Sounds ok on the whole, really need a bigger room.
