£5 for 2 sets plus postage John.
Whils we are on the subject of RCM's whats the general consensus on making a home brew liquid to clean the records.
I have now finished my home made RCM and it works a treat, quite proud of it to be honest and many thanks to fellow art of sound memeber "oceanobsession" for helping me out through the way.
I am about to get me some IPA from maplins, Ive got the distilled water, just got to get me the photo stuff or can I use fabric conditioner to break the surface tension of the water?
Any help much appreciated
Lee
Vinyl rig 1 - NAS Spacedeck / FR64s / Lab 12 Melto / Denon SUT / Ortofon GM SPU. Vinyl rig 2 Mono Set Up - Lenco GL75 c/w Jelco 750D / AT33 Mono / EAR 834P Modded. Amplifiers - Audio Note Empress Silver / Hattor Passive Pre. Digital - Fanless Mini PC / Lampizator TRP / Linear PSU / Hummingboard Network audio adaptor. Speakers - Horns.pl Mummy's. Cables are Audio Note / Albedo / Furutech Speaker wire. Power conditioner is a Gigawatt PC2 EVO
I use Kodak PhotoFlo or whatever it's called, but I suspect cheap washing-up liquid or similar works just as well. You're not using much of it after all.
Keith
Analogue: Lenco L75 with 'PTP5' top plate in heavy birch ply plinth/re-wired Rega RB300/SAE 1000e HOMC Cartridge/Trans-Fi Reso-Mat/Moth RCM
Files: Voyage MPD/Custom PC/Supra USB/Beresford ASYNCH-1/Beresford TOSlink cable
CDP: Inca Katana SE
DAC: Beresford Caiman MkII (LiPo Battery powered)
Pre-Amp: Croft Micro 25 Power-Amp: Croft Series 7
Speakers: DIY Frugel-Horn Mk3 ('FH3') + REL Strata subwoofer
Headphones: Beyer Dynamics DT990 Pro (250 ohm)/Schiit Asgard Headphone Amp
Cables - Interconnects: Mark Grant G1000HD Speaker Cables: Van Damme Blue
Mains: Belkin PF30/Mark Grant DSP2.5 & DSP1.0 Rack: Target
Office System: HP Win8 Laptop/JRiver/MF V-Link2/Beresford Bushmaster MkII/Topping TP20 Mk2/Mission 771e
Bedroom System: Raspberry Pi/Raspbrian + MPD/HiFiBerry DAC/Topping TP20 Mk2/Mission 760i or DIY Hybrid Valve-MOSFET Headphone amp + Sennheiser HD595
Gallery
Thanks for that, any idea as to what ratio people prefer to use for the distilled water to IPA?
Cheers
Lee
I'm Mark.
4 parts water. 1 part ipa. Doesn't have to be exact.
Mark
That's exactly what I use - 100ml IPA in a 500ml bottle topped up with distilled water. Add wetting agent (PhotoFlow, washing up liquid etc) a few drops at a time with a pipette, shake then test by dropping a little of the mix from a pipette onto a tile/mirror/glass etc and seeing if the drop spreads out nicely - if it doesn't, add a bit more wetting agent and repeat until it does.
I also use a pipette to apply the fluid to the record - 2 to 2.5ml per side is just right.
Keith
CDP: Inca Katana SE
Gallery
Cheers guys, finally is there a specific brush that people use on here to apply the liquid, I was going to use my carbon fibre brush I use to clean the record prior to playing it, but if there is anything better then let me know
Thanks
Lee
I like the KAB DiscSweep brush from http://www.kabusa.com
When I bought mine earlier this year it cost about £15 including delivery (which took just over 1 week).
Keith
CDP: Inca Katana SE
Gallery
