I'm Mark.
*Parasound HCA 1500a Amplifier.
*Dared SL-2000A Pre-Amp, Psvane 12AT7's, Brimar Rectifier.
*Basis 1400, RB300 w/Incognito, Audio Technica T33EV
*Technics SL-1200 MK II, Sumiko Premier MMT Tonearm, Audioquest Tonearm Cable, Applied Fidelity Bearing, Isonoe Footers, Denon DL-103R.
*Highly Modded Cambridge Audio 640P Phono Preamp.
*Squeezebox Touch
*Grant Fidelity DAC09 DAC.
*Snell Acoustics Type EII Speakers.
There could be, David, if you got rather 'excited' listening to a particularly engrossing piece of music!I can find no evidence of moisture...
A lot depends on your environment. It's not unusual for my room to hit 70% humidity, I bring it down to 40%. Many rooms will see 60% (mine's in a cellar). As I said, I use poly-lined but keeping anything in plastic when not inserted in low humidity and then fully sealed could lead to a problem in years to come. I'm thinking here more of records I have which are worth a fair bit but don't really get played.
