Would substituting a 3.9 uf for a 4.0 uf film cap alter the cross over point enough to make any real audible difference?
Jeff :UBERTHREADKILLER
Not really no... Most capacitors are rated at 5 or 10% tolerance.
Bests, Mark
I wonder why they don't just call them all 4.0 uf caps then,why 3.9 ,4.0 ?
Jeff, some do manufacture closer tolerance components. 39 or 3.9 or 390 is in line with the resistor values so not too far out of whack
The 4uf capacitors are more out of line of standard values in reality
Bests, Mark
No Jeff, don't worry about it m8 There are what is know as 'standard values' in most components, but there are also much closer tolerance components available.
3.9uf is much more in line should I say than a 4.0uf capacitor. If the 4.0uf capacitor is more than a few years old it really won't be precisely 4.0uf, it'll likely be between 3.8uf & 4.2uf & that is going on a 5% tolerance. 10% = 3.6 & 4.4uf
With standard values you'll get a good enough replacement as 3.9uf is as you can see pretty close to the mark.
The same standard values are applied to both resistors, capacitors & as a third inductors. You want something that doesn't come in those then it'll cost you...
Bests, Mark
I'm Nobody.
Jeff:
i'll send you some notes regarding value Standardization
Thanks guys,
I get it now,Andre after reading a little it makes sense not to have a whole lot of caps just a 10th of a percent apart from each other.
I just don't get why they didn't use nice round numbers like 1.0 1.5 2.0 2.5 ect....
But that's ok.
How long will film caps stay in spec?
I know electrolytics can begin to drop after 10 years.
I doubt a film cap will likely go out of spec in your lifetime Jeff, unless it was subjected to more than it's voltage rating or other forms of abuse
Bests, Mark
