Results 1 to 10 of 11
Thread: Wanted: Speaker cable connectors for Leak speakers
    I'm Juha.
    Default Wanted: Speaker cable connectors for Leak speakers
    Hi all.
    Would anyone have speaker cable connectors, which connect back of the Leak speakers(two pin speaker connectors), for sale? I am looking these for my Leak Mini-Sandwich speakers.
    These connectors are basically two hollow tubes fitted to the fixing bar, one tube bigger that the other in diameter.
    Cannot find any pictures to attach and cannot explain any better , sorry.
    My Gear
    Source components:
    Garrard 401 in a solid birch plywood plinth / Trans-Fi Terminator T3Pro / ESCo modified Denon DL-103
    Pioneer TX-9800 tuner
    Amplification:
    Art Audio Diavolo and Conductor, Pair of XTZ Sub Amp 1's, Nick G 'Dual Phono' phono stage
    Loudspeakers:
    Bastanis Mandala Atlas with 15" sealed woofers
    Cables:
    Analysis Plus: Big Silver Oval speaker cables and Silver Oval-in interconnects, Mark Grant DSP 2.5 Dual Screened power cables
    Record cleaning
    Nitty Gritty 1.5Fi MK II
    I'm Mark.
    what about a pic of the rear of the cabinet?
    I'm Mark.
    try contacting "Greenhome Electronics", they're very helpful and may well have the fittings you need
    I'm John.
    Are these what you're looking for?
    http://www.ebay.co.uk/itm/Connector-...item2c6048c527
    Sent by me using an appendage
    SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
    Luxman 509X amp.
    PMC 25 23i speakers.
    Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
    Cables by Kimber, Yannis and Audioquest.
    Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
    I'm Juha.
    Good idea, thanks. Forgot that the fleabay listing had a picture of the connector and the speaker binding pins . See third picture on the listing.
    http://www.ebay.co.uk/itm/1905885913...84.m1439.l2649
    The distance between the speaker's pins is 12mm. Positive pin is 2.5mm on diameter and the negative is 3mm.
    Quote Originally Posted by worthingpagan View Post
    My Gear
    Source components:
    Amplification:
    Loudspeakers:
    Cables:
    Record cleaning
    I'm Juha.
    Thanks for the link, but these DIN connectors are too modern for my speakers. Just added a fleabay link where the connector is shown.
    Quote Originally Posted by prestonchipfryer View Post
    My Gear
    Source components:
    Amplification:
    Loudspeakers:
    Cables:
    Record cleaning
    They haven't been made for 40 years or so. Your only hope is E-Bay or replace them with modern connectors.
    I'm Juha.
    Hi Dave.
    What would you call these connectors for me to try find them on ebay?
    Leak speaker connector?
    My Gear
    Source components:
    Amplification:
    Loudspeakers:
    Cables:
    Record cleaning
    I'm Nobody.
    Juha:
    If they are the same diameter holes as the Leak 'Stereo 30/70 & If your desperate a 3mm & a 4mm Banana plug will do the job.
    I'm Juha.
    Hi Andre.
    It is not plugs that I am looking for actually, just the opposite . The Leak speaker's binding posts are 'plugs', one 2.5mm thick and another 3mm thick. So I am looking the female parts of the connection, which I could fix to the speaker cables.
    Quote Originally Posted by Andre View Post
    Juha:
    My Gear
    Source components:
    Amplification:
    Loudspeakers:
    Cables:
    Record cleaning
