Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
Thread: Jelco SA 750D.
  1. #41
    It will have the same resistive effect.
    I can only think of one maker that damps the arm/headshell actually at the front and that's Townshend. SME and Mission arms use a trough & paddle just ahead of the arm pivot point. Decca, Mayware and others have a fluid well within the arm pivot top.
  2. #42
    I'm Ake.
    I am planning on using a Denon 301 mk2 on a Jelco 750D,do I need extra wight on the headshell then?
  3. #43
    I'm Ralph.
    I don't think the DL301 suspension is as stiff as that of the DL103 so I'd go with the stock headshell for starters and see where it takes you.
    Ralph.
  4. #44
    I'm Ake.
    Ok,when I bought the 750D I got the original counterweight but allso a one wich weighs more,wich one to use?
  5. #45
    I'm Rav.
    I ran a SA-750D with a DL301-MKII for a short while, simply because that was the only cartridge I had spare on hand. I used both the stock Jelco headshell and also a Audio Tecnica AT-LH13 headshell. The Audio Technica headshell worked much better.
    You will not need to use the heavy counterweight. I was suprised that the DL301-MKII worked surprisingly well in the SA-750D.
  6. #46
    I used a 103 on my Garrard 401 i a 750D. I used the Sumiko headshell and it tracked no bother. Whether it will suit your Rock though is a different matter.
  7. #47
    Quote Originally Posted by Temsa View Post
    You will not need any extra headshell weight. The 301 mk2 is quite a different beast to a 103.
  8. #48
    Imho you can run Denon 103 but this cart does not behave great in the Jelco. To me it seems like weight wise all is matching but i think some internal construction is not completely on pair to behave like real heavy arm Like Fidelity Research type ones. I really like Jelco with Denon 207,301 and 304 also Zyx works very good. I think jelco might be very solid performer for all carts that require medium mass to light heavy arm. I used ortofon 9000 shell for weight and ADC magnesium one when i needed to reduce mass. I did not like damping fluid at all and got rid of it quickly. I think this arm is good till Reed /Triplanar/sme level. I have 10.5 version of this arm .
  9. #49
    I'm Ake.
    Today I got my DL301 II,and it came with a overhang dummy shell,for adjustng the overhang.
    But how much should the overhang be?
  10. #50
    I'm Bastien.
    Quote Originally Posted by Aethelred View Post
    Do you think the 12" Jelco (750L) could work better with the DL-103 (heavier, effective mass is 26g).
