Yes, but you'll need something like a Behringer DCX2496 to time align the drivers..
Luckily it'd do everything else to integrate a 3 way system... Gain, time delay, crossover rolloff & type etc...
Not perfect though, you see you need to feed it a stupendous voltage level level to make it use all the 24bits it's capable of using...Then you need to step it down to fit in with hifi amps...
Well i'm dieing at the quality of it non stepped up already, when i get this extra 25Db+ of input through modification & all the 24bits i guess i'll know what real linearity is Right now it is better than any 16bit system...
