You'll need to ask Guy about the reasoning. The 24th of this month when I'm coming down to your 'domain' - Guy's going to join us
Ah!!! got it! Two packets of chocolate digestives then??
Dave
Certainly the copper was an improvement on the stock mat. I got hold of it because I heard a friend's Mk3, which has a gunmetal platter. He played me some records both with the mat, and directly on the platter. The sound when placed directly on the platter was astounding - especially the piano tone. The only downside was the loss of some edge to the brass instruments. The mat's actually a Micro-Seiki CU-180 which is what Guy's are based on.
Fascinating!! How thick is it? Don't understand the 'impedance match' though, I would have thought it is was way too low?
Dave
It's about 5mm thick (it's pretty much a perfect fit for the recess on the SP10 platter). Not sure about the impedance match, I'm not a mechanical engineer, but it definitely sounds better than the stock mat. I don't feel the urge to fiddle at the moment, but I'd certainly like to try other types of mat at some point.
I'm Gareth.
If my missus came home to that, it would certainly cause and effect something alright.
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
