Results 1 to 10 of 14
Thread: Technics SL-10 rework
    I'm Liam.
    Default Technics SL-10 rework
    heres a little thread about my sl-10, ebay find a few months back, cost a little over 125, which was ok, when i recieved it, it was more heavily knocked about than i first thought.
    With lots of marks, and most annoyingly a broken catch that meant the lid wouldnt close properly. u can see its sitting proud on the left hand side.
    The original 310mc cart had unfortunatley been damaged with a broken needle, but i had sourced a new old stock 310mc from the usa, which was alot more than the table itself.
    Hooking it up an ortofon OMP10 it did play however, and didnt sound to bad considering, it wouldnt get to the end of the record however, which pointed to a worn arm drive belt. other than that here's what it looked like.
    By rabid1981 at 2011-09-27
    starting disassembley of top cover.
    here you can see the drive belt, and where its gone oval due to age.
    lifting the plastic strip to uncover the top screws for the acrylic window.
    after removing platter and bottom shroud, heres the main pcb.
    some of the electrolytics on the phono amp side.
    here's the bare metal chassis, with pcb, and bearing etc removed.
    ordered up a new drive belt and electrolytics for both the main pcb and the arm control board, nothing fancy, just nichicon series.
    also some vw satin silver paint and a some sundries like isopropyl alcohol and some 400grit wet and dry.
    had to make a mold for the latch assembley as its so small i cast it in two stages with latex forming the two halfs and a Polyurethane casting resin, with some black paint to spray up the finsihed part, as i ddint have a suitable dye.
    will post the recap next, and reassembley.
    Bloody-ell, you're keen
    A darned good little deck that one and I remember it embarrasing a Basik 'Sondek at the time, although we'd never admit it
    I'm paul.
    very interesting post
    Paul
    Thorens TD 124, Thorens 12" Arm refurbished by Alfred, Shure M55, Denon 103r ,whest PS30R , Auditorium A23 Sony XA20 ES, Benchmark DAC 1 HDR, Elite Townsens 600c Pre,
    DPA Enlightenment DAC, , , Radford STA 25 Series 3, Aurex ST S80 , Tannoy Monitor Golds 15" Tannoy York Enclosures, TEAC DS H01, Isotek Substation, Abbey Road Reference Speaker Cables
    and some other stuff
    I'm Jim.
    I have a Technics Sl-10 that stopped working.
    The platter spins when I push the button under the lid.
    The tonearm doesn't move when I push the start or the cueing button.
    I have been told there is a belt under the lid that controls the tonearm.
    I have looked at the schematics and it would appear to be a complicated repair.
    Hi 'speakerman19422',
    Welcome to AoS!
    Before posting anywhere else on the forum, please pop into the Welcome section and introduce yourself to our community by providing your real first name, approximate geographical location, and details of your current system and music tastes, as this information is required of all of our members.
    Cheers!
    http://www.thestainedglasscompany.com
    "A man is a success if he gets up in the morning and gets to bed at night, and in between he does what he wants to do" -- Milan Kundera.
    I'm Nat-andthat'swhyIdrink.
    Looks rather familiar - same motor as the 1210, similar board design (if looking more cheaply put together), same control IC..
    Is the bearing the same but with a thread and nut to hold the platter?
    This was a great performing and sounding deck at the time and could easily better an average LP12 if sited correctly.
    Hope it's now sorted and giving pleasure
    I'm AnDreW.
    I love a good restoration thread, keep them pics a coming
    SS CD Teac VRDS25X(Mega Modded) DAC Caiman SEG+Anker PSU DECK 1210 Mat Analog Studio Crystal Mods MN Base/Bearing/Platter+Ebony arm Board Feet Isonoe PSU Paul Hynes SR7EHD-27XL/DCSXL Ag DC lead/Jaeger(low-impedance) connector/3 StageRegs/Recapped PCB+No Pitch/Strobe/Light ARM SME V(Kondo Ag Rewire&Tags) MC Cadenza Black CABLES Arm Yannis SPD-4 IC Yannis 222 Litz+Ag bullets Power WAR PRE ATC SCA2 SPEAKERS ATC 50ASL STANDS Atacama PHONO Sugden Masterclass PA4 SUT Ortofon ST80SE POWER PSAudio P10
    Valve PRECroft Epoch(Mega Modded) AMP Sondex S100 SPEAKERS Tannoy 15"MG+RFC Warwick cabs+ Reference XO DECK Garrard301 MatTeunto GunMetal Bearing SPH Plinth Moldovan Arm SME 3012(Ikeda Ag wired) PSU NSC MCAg Meister SPU/DECCA Maroon CABLES Arm Yannis 420.5 Litz+ Speaker3mm2Ag IC Oyaide FTVS-510 AgWBT 0110Ag Phonostage Paradise
    I'm Bob.
    Don't know how I missed this thread originally! I've a couple of Technics parallel trackers - SL7 (LP-sleeve sized like the SL10 but without the SUT), and its full sized equivalent, now Vantage-tricked-out, SL-QL1. Both make amazing music. Maximum kudos, Liam, for the restoration and great pictures.
    Here are mine for the linear-tracker nuts out there . .
    The platforms are from SRM/Tech, that for the SL7 being a custom made one.
    I'm Andy.
    Quote Originally Posted by morris_minor View Post
    Looks sweet Bob- the acrylic platforms any cop?
    Me so horny- Impulse H6 Horny
