Results 1 to 5 of 5
Thread: Keeps logging me out
    I'm Anthony.
    Default Keeps logging me out
    Forgive me if I've missed the plot but is some way I can stay logged on longer.
    By the time I've completed a message I'm offline.
    Please Advise
    Regards
    Tony
    Alex_UK's Avatar
    When you log on, check the "keep me logged on" box (or similar, going from memory) and you will be fine.
    Alex
    MartinT Guest
    Sounds like the session is breaking; are you working from a poor wireless signal by any chance, Tony? Or from work via a proxy?
    I'm Anthony.
    You're up late guys
    I'm confident my connections ok. I'll try Alex's suggested and get back if I have any further problems.
    Goodnight Guys
    Tony
    I'm ChrisB.
    Alex is yer man here - if you don't tick that there little box, you get the door slammed in your face after 15 minutes
