S'ok, I'll torture it out of you at the Toyster's party
No one having a comment on that cathode follower? At higher output it will distort (the same with emitter followers of course).
IMHO the bandwidth is rather small and he didn't measure distortion at (very) low and high frequencies.
John
Music is an emotional experience. Without it, living would be a dull habit...
We use a cathode follower with the intention of having a low impedance at the output. This works fine but, having a resistor in series between cathode and ground, the current will vary with the signal. So the tube is "swaying" along its curves when a signal is fed through. Those curves are not really linear and distortion will be the result.
A good thing then is to use a constant current source instead of that resistor. That current source could be a tube or a transistor. When using a tube the Lofton-White follower comes into the picture. The latter has an output impedance <500 Ohm.
Another way to achieve a low output impedance is using a kind of SRPP or Mu-follower. That gives an output impedance of around 1 - 1,5 kOhm and very low distortion. If the interlinks are shorter then, say, 5 meters the signal will stay linear up to around 500 kHz.
John
