Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Quad 33/303 developed a problem
    I'm Dan.
    hi
    all fixed thanks
    Dan
    Pre & Power
    Technics SUC 909U & Technics SE A909S
    Turntable
    CD Transport & DAC & PSU
    Loudspeakers
    Tannoy 615 MK2
    I'm Nobody.
    What was it Dan ?
    Quote Originally Posted by dantheman91 View Post
    Din lead from the pre amp to the power amplifier and i think there connected up wrong because
    din1
    ground
    wires clear and blue together
    and
    red and yellow wires together
    Din 2
    Ground
    wires yellow and blue together
    wires red and clear together
    could be wrong
    Dan
    No wonder you are only getting mono reproduction: pins 1 (left) and 3 (right) are connected together (twice, first by the yellow wire and second by the clear wire). You need to cut the yellow and clear wires at each end, leaving you with:
    Pin 1 blue wire
    Pin 2 ground (shielding)
    Pin 3 red wire
    Don't connect anything to pin 4.
    I can thoroughly recommend Flashback sales for their DIN leads; they use good quality metal-shrouded plugs and good quality twin ('figure of eight' or 'shotgun') coaxial cable. I have used a few of their cables, where i have been too lazy to make my own.
    If you have difficulty obtaining a replacement cable, let me know. I probably have a Quad cable lying around somewhere you can have.
    I'm Dan.
    Hi
    andre and barry ye it was the din to din cable the guy wired it up wrong.
    now its back to being stereo again i will need a new din to din i will keep you in mind barry thanks
    Dan
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
