Yep, single ended, so always A. They were running at about -7v on the grid when idling, so the challenge is to find a driver stage that will handle the 80v P/P signal, but also the grid current of 50ma or so as the grid goes positive (A2) for half the signal and negative (A1) for the other half.
It was just a lash up for the day, so no protection built into it specifically, but a lot of monitoring at startup. Paul built the output stage and heater supply (10A @ 10V), I built the driver stage, ECC40 to augmented cathode follower (12AX7, 12BZ7, 6BX7). The two parts had never met each other before the day (we just agreed on the plug and socket to connect the two. The power supply and driver is aimed at a big SE project, but not 833. There was a 5A fuse in the 1500v power supply, does that count? In fact, it was a expensive gold plated one, it was the only 5A 20ma fuse I could put my hands on at the time :-). Oh, and I did put a old perspex turntable cover over the HT supply to protect from fingers on the cap terminals.
As for efficiency, yes thats 220W per side, + 100W for the heater. As you say max efficiency for SE is 25%, but thats only true for A1 operation. As A2 can get you closer to the diode line, max efficiency is closer to 40%. Just dependent on how far the driver can push towards the diode line. I dont think the is a solid state equivalent of 2 (because of course you can have B2 and AB2 push pull amps). Thats why I can get 32W out of my 211 Set, though thats a much easier valve to drive into A2.
