I'm Nobody.
Sorry Andr'e, it appears i was suffereing from temporary blindness & i hadn't read everything
Bests, Mark
I'm Nobody.
s'ok a few suffer from it, i'm as guilty as sin
Thanks guys, that's exactly what I was after. I'll check the local B&Q for it. Do I need to undercoat first or paint it straight on with a clear coat on top?
Mark, I wondered how you got that finish on your speakers. Looks great!
Bernie.
Cheers for the complement
What you want to do is decide which colour you are going to use as there are quite a few. I tend to use "Manhattan Mist" which is the darkish grey colour of my speakers, but you could use any other you wish.
What you need to do is find an undercoat that will be approximately the same colour as the main colour of the Fleck Stone. Me i use grey undercoat for obvious reasons.
So a few coats of undercoat, then the Fleck Stone (might be known as "Stone Touch" nowadays) & finally an Acrylic laquer of your choice, i tend to use a satin laquer as i don't want the things too shiny.
Hope that helps
Bests, Mark
I'm Nobody.
You make me so happy Bernie biggrin.gif I thought i'd check the orange one myself but online &.... Bravo You just saved me £4 a can from buying the stuff on fleabay. However i must check Focus out but their site is down, i guess that is because they are selling everything dirt cheap as they have gone into administration I bought it from them previously, hope they have a decent stock, i'll buy the lot if it's reduced
Only about 500M from me so i'll do that tomorrow
Bests, Mark
Worth checking The Range too if you have one near as I believe they stock it, and are usually cheap.
Alex
Amplifier: Rega Brio R. Speakers: Spendor SP1. Cables: Various, mainly Mark Grant. Please see "about me" for the rest of my cr@p! Gallery
Just checked Alex, nearest store is miles too far for me. Might be handy to someone else though
Bests, Mark
Just bought some Manhattan Mist from Focus. £7.99 per pressure pack. Lucky I did as when I went to B&Q they didn't have any. Bought some primer and clear for £6.98 each though, which was cheaper than Focus. Thanks for the tip Mark.
I'll let you know how they turn out when I'm done.
Bernie.
