Andr'e is right and the option once output devices are changed to remove or significantly relax the current limiting (4A to at least 8A) would help with more modern low impedance speakers. Possibly the fully-complimentary conversion which can be done with current transistors.
Please check out the Dada website as well
Of course, if Quad thought that the original tweak was a good thing, don't you think they'd have done ot at the time?
Others' work on the equally antiquated Naim amp design shows that there is an optimum bias current level and increasing it makes no beneficial difference - see the Acoustica site for links regarding this..
