Dave, why did you reverse both the diodes & capacitors? It's wrong...
Go back to the diagram you had previously & simply reverse both capacitors
Bests, Mark
That's the way to do it
PM me your AD & i'll send you one of the MUR3040PT, I know where they are so it's not like i have to go hunting them down
By the way, depending on what you are going to power you'll need to take into account the current carrying capacity of the capacitors, check out there ripple current rating.
Bests, Mark
Mark,i thinks its time you started designing and making some products.
Making my own stuff is as far as i'm willing to go Colin I don't mind helping out like this & i can't stand stuff that's wrong, god knows what that bloke was thinking when he posted that circuit on the net
Oh sorry, what am i on about? He wasn't thinking
Bests, Mark
Here's another DC blocker schematic I've just found:
What do you think about that one Mark? Would this be any better or worse?
Source: Apple TV 4K - DAC: Beresford Bushmaster Mk II - Preamp: CI AudioPLC-1 Mk II - Power Amps: Musical Fidelity 550K mono blocks - Speakers: Wharfedale Opus 3 - Cables: Mark Grant etc - Misc: Belkin PF30 mains filters.
Why bother making something more complicated than it needs to be? It'll be more expensive & work no better than the two diode two capacitor version
Besides which the diodes are back to front yet again!
Bests, Mark
Ok thanks Mark.
I can see that if you chop the right hand side of that last circuit off you're left with the circuit you recommended.
It's quite scary that both of the first to circuit's I posted are wrong and they've been in circulation for several years with many people making and using them. No wonder quite a lot of them said they didn't notice much difference in transformer buzz after installing it.
Google can be a dangerous tool at times. I'm glad I asked before I jumped in.
Cheers.
They will probably work, in fact they will work with the diodes back to front as long as little DC voltage is present on the line. However with the diodes wrongly orientated the capacitors have zero protection against DC reverse voltages greater than 0.7V. What this means is that if there is significant DC on the line then the capacitors could well blow up
Bests, Mark
Nice.
I'll drop you a PM in a minute about the diode. Thanks for the offer btw.
On the subject of caps, I have a few of THESE left over from my valve amp build, would they be chunky enough? Cheers.
