Anyone seen or used one of these? https://www.ripcaster.co.uk/node/308
Looks good,if on the pricey side.Says there's no need to use with a pc.Ok,I can see you don't need to use one to rip your cd's onto it,but how do you select what you want to play back? Looks like you'd need a pc to do that,or a better solution would be to use a SB Duet? I'd like to go down this sort of route,but I don't want to be faffing about with my pc every time I want to change tracks.You'd think for this price it'd come with something like the Duet,but I can't find out if it even comes with a remote! Any thoughts?
