Since im now settled on my Philips cart i thought id look into getting a more suitable counterweight!
This cart is 6g and it would seem that this is the limit for the stock counterweight as it is practically hanging off the end of the end stub!
when I had my jelco, the heavier weight that sat right close to the pivot seemed to make things sound better too ...
so, what are my options
i was thinking a technoweight would be the perfect option
http://www.michell-engineering.co.uk/tonearm.html
but it says "One counterweight matches cartridges of 3 to 6g mass, the other is for cartridges of 7 to 13g"
am i not just going to be in the same situation again?
so is there a solution
or any other to consider?
this one looks interesting ...
http://cgi.ebay.co.uk/XTCW-REGA-NAD-...#ht_938wt_1139
also will i be able to swap the end stub and cw my self?
