Hi Andrew,
Thanks for taking an interest. I would have liked some BHC as well.
I'm looking for audio quality caps really. Those caps that you linked to look more general use items. Is that right? Or am I talking out of my hat?
I'm Lucky.
Hi Andrew,
The Man with the suit and the pace. Knee deep in the dead.
Well i went looking & couldn't find a lot
Can we have the exact capacitor dimensions please as i'm guessing they'll be 105mm long (common) but the 45mm diameter just doesn't sound right 50mm is common & so is 37.5mm & it sounds suspiciously like they might be 50mm (often 51mm or 2")..
Bests, Mark
What they dont have they can probably get for you.
http://www.audiocap.co.uk/ft-4700uf--63v-280-p.asp
Single spur balanced Mains. Self built music server with 3 seperate linear PSU, Intel i5, 16 GB RAM no hard drive (various Linux OS). Benchmark Dac2 HGC, single ended XLR interconnects/Belkin cable. Exposure 21RC Pre, Super 18 Power (recap & modified). Modded World Audio HD83 HP amp. Hand built Monitors with external crossovers , Volt 250 bass & ABR, Scanspeak 13M8621 Mid & Scanspeak D2905/9300 Hi. HD595 & Beyer 880 (600 ohm) cans.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts.
-Bertrand Russel
John.
Had a search round all the usuall suspects.The 100v rating make them expensive but I found these in stock:
http://cpc.farnell.com/vishay-bc-com...t=15000uf+100v
Whats the rail voltage ? If you could get away with 63v then more choice/cheaper.
I've got some new 100v BHC caps here that I could do cheap but they are 47000uf/68000uf and alot bigger.
Paul.
Nice find, i reckon they would fit if Darren cares to measure them properly
I was thinking the same thing about the rails, 80V DC caps may well be ok but 63V is a bit of a drop from 100V DC rating..
Bests, Mark
I'm Lucky.
Hi everyone,
Many thanks for the links and suggestions. I'm sure one of them will work out a treat.
I'm Nobody.
Paul
I'm i seeing things or is that a White Incatech 'Claymore' amp in your avatar? There's only like a couple of those ever made right?
Yep,one of just two made.
Sat on my other TOCA.
Me likes Colins amps............
I'm Lucky.
