Results 1 to 9 of 9
Thread: PC not included...
    Default PC not included...
    Apologies for the quality and untidy mess in the picture. It’s a quick snap with the camera phone of one of my workbenches with my PC-less music server.
    A while back I mentioned that I used just a hard drive with my music on it, directly connected to my DAC. This is the set up in use whilst I had to test something.
    The HD is loaded up via a PC and can play back both audio and video files. It has a coax output, which I set to PCM for use with the DAC. The HD comes with a remote control so that you can scroll through your music folders and select your track to play.
    The content has to be viewed on a display. I am using a TV with an AV input that accepts composite video. The connection method between the two also allows the TV to be used as a music playback medium. So you don’t have to use the DAC to listen to music all the time. Good for quick content scanning of the HD.
    There is also a secret folder option.
    Total cost of the HD, TV, and DAC works out at £300. Far more flexible than a PC, and it doesn’t crash.
    Nice one, Stan. Is that a pair of AKG headphones I spy there in the corner?
    Yep. There are a couple of other makes and models out of shot that are also used for testing purposes mainly.
    K701s? If so, snap - they're quality
    I'm Nat-andthat'swhyIdrink.
    Err, snap with the soldering-iron on the left...
    Do those harddrive media players sound ok?
    Those HD players are fantastic. The one I have can be operated as if it is a DVD/CD player. So you can go to a particular track in any CD Folder as if you were looking for a track on a CD. The digital output is flawless and far more stable than a CD or DVD. The latter two can suffer from skipping etc. The HD doesn't skip, doesn't suffer from dirty laser pickup, and doesn't scratch my discs.
    It is also better than a PC, since there are no interruptions such as incoming mail warnings whilst you are listening to music.
    And it is flashy. I have had quite a few people email me for further info on my set up. I reckon that this is the first time that most folks would have seen an actual HD system like this in use anywhere on the net.
    I'm ILOB.
    Can you explain your system in detail the equipment you use how you connecting it. It sounds a really interestng set up
    A few people have asked me that same question. So I am going to take a couple of pics and make like a running instruction set. I'll put it on my site and let you guys know the link.
    Stan
    I'm ILOB.
    Cheers Stan
