Originally Posted by
Emmodd
1. Does itunes create it's own folder ie duplicate the music i'm importing (because i've noticed a lot of tracks are on twice). If so, is possible to easily delete the duplicate tracks from the library and is there an easy was to alter the tags so that the correct songs stay in the correct 'album'? Should I do this in the itunes folder only (otherwise if I rescan, it'll no doubt have to convert a number of files to ones which itunes can handle)?
Yes, iTunes creates its own folder (assuming you check the 'create copy' box in the advanced options). Once you have dragged all your music files into iTunes you can go ahead and delete the source files as they are duplicated. The only file type iTunes has a problem with is FLAC, but do a search on Google as there are a range of free plug-ins that add FLAC capability.
Emmodd
2. If itunes does create it's own folder, when I have my mac, what it the best way to get my itunes library on there? Can I just copy across the file by firewire, usb etc? Can I copy across to an external HDD and point itunes on the mac in the right direction?
Connect your external hard drive by USB or Firewire and drag the whole lot into iTunes, then delete the original files. Alternatively you can point iTunes to any location you like, simply select the location in the advanced options pane.
Emmodd
3. Is the duplicate track thing just a pc problem because i'm running apple software on it?
The duplicate thing is a PC problem, but Apple sorted that out a long long time ago.
If you're after sound quality though I'd advise dispensing with iTunes and changing to Max and Cog. Max is import software that does many passes to eradicate any errors (as many as you like) and Cog is playback software that is very simple and easy to use - the combination of the two is unbeatable for sound quality as far as Apple software playback goes. No bells and whistles mind, but that's hardly the point of hi-fi is it?
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
