Technics SL1210 with
SME IV Arm & AT OC9XML,
Firebottle modded Tron Convergence Phono Stage,
Bluesound Node 2i, Technics SL DZ 1200 CD
Denon PMA1700ne amp
Yamaha NS1000M Speakers.
Hi Ben, PM activeXP (Steve) & ask him for the driver parameters as i did this previously & he had them. You see he used the same drivers in his experimental double chamber reflex enclosures. Just wish i'd kept the data
Try to get as much info as possible ATB, Mark.
Bests, Mark
currently banging my head against the wall trying to get WinISD Pro to work. it wont save any of my data and thus i cant get it to model anything................
Any ideas anyone ? I can imput the parameters ok but it then wont save and sometimes whe it does seem to save (to desktop) I then cant review it at all. siiiiiiiiiiiiiiiiiiigh.
Denon PMA1700ne amp
Open the driver editor, stick in only the parameters i mentioned in my PM. Then hit advanced parameters & go back to parameters & a good load of blanks should be filled in.
Before doing anything you'll need to name the manufacturer of the driver, then the make as well & the model of driver - don't miss anything You need to fill in 3 things to name it etc.. So "Tang Band" "Tang Band" (again) & model #
Once you have done the above hit "save" & a window should pop up asking if you want to save it as it is... Don't try to save it somewhere else, the software knows where to put it
Let me know how you get on...
Bests, Mark
Brilliant, worked a treat Mark . And to think I was pulling my hair out trying to get this far last night lol All i needed to do was save it in the location given
Ok so iv progressed through a few screens choosing a vented box.
Its now giving me 5 choices
QB3 Quasi butterworth
BB4 SBB4 (super boom box)
C4 SC4 (sub cheby shev
etc
etc
What do these mean and which should I choose?
Denon PMA1700ne amp
There you go, you just need to listen to speakermark
Ok, select whichever you want Me i just selected QB3 (quasi butterworth) & went from there... After looking at the p*ss poor bass responce i increased the box size & lowered the tuning freqeuncy to make an EBS (extended bass shelf) @ -6Db. This would be great for use flat against a wall, frankly it's the only way you'll get any usable bass out of the things
This is what you'd end up with:-
Unfortunately if you then click on maximum power (look at the smaller window second from top left & click on it you'll get a drop down! "transfer function magnitude") you'll soon see it's excursion limited & power limited
Bests, Mark
Cheers SpeakerMark, I deffinately owe you a few virtual beers for all this help mate.
Im getting an error message up saying "floating point division by zero" any ideas what iv done now ?
Denon PMA1700ne amp
Yeah, the decimal point is tiny in the box tuning frequency or box size What you have done is left two or more decimal points in there & it's having a bit of a freak out
Bests, Mark
Great got it now.
So the graph you show is that the "ideal" shape i should be aiming for ?
Denon PMA1700ne amp
