Originally Posted by
Reid Malenfant
Did you use a foam roller with the Hammerite Adam? Looks like a nice job from what i can see
Definately better than the silver finish
Hi Mark, no i ended up with some spray paint for the job, i couldn't find any hammerite in my local (tiny) DIY shop, there is a couple of dust particles under the paint on top of the amp but you really have to look to see them, had to work in my shed in a make shift spray booth (a sony av amp cardboard box), but it did the trick.
I may give them another few coats over the next few weeks just to make the coat thicker and more robust.
I cant seem to find any gold/brass screws to use on the side to screw the lid to the chassis, think there M4 6mm, there bit bigger than the back screws which i think are M3, might have to pop into my local PC shop and ask them.
Just going to wait now for 2 days before i hook the system back up so leaves the paint plenty time to harden.
Adam.
[Main Room Audio/Video:] TV: Toshiba 32LV665V - AV Amp: Sony STR-DH810 - BD/DVD Player: Sony BDP-S360 - Speakers: Sony SS-MS155
[Bedroom Audio:] Amp: Teac A-H300 Modded Pre/Power Amp - CD Player: Teac PD-H300 - Speakers: Eltax Wave Mini - Interconnects: QED Performance Audio 2 - Speaker Cable: QED Silver Anniversary XT
