S'ok, Mikey, I knew you were a bit of an expert on this
Next time I've got the lid off of the Croft, I'll have a look at the CV4004 and let you know.
I probably need to get a life too, as I find all this stuff fascinating!
Only since this morning!
If anyone fancies a nice M8137, this looks like a good bet:
http://cgi.ebay.co.uk/M8137-ECC83-Mu...item56430b8a56
I'm Clark.
Marco
The ECC808 is probably the best ECC83 variant I've ever come across.
Uses a different pin out configuration but if the sockets are hard wired the mod is simple and reversible.
Even if you can't use them currently, it's a good one to remember for the future.
http://cgi.ebay.co.uk/1-X-ECC808-VAL...ht_3864wt_1207
Hi Andy,
Noted, dude
I'd forgotten about the 85A2 voltage regulator valve that's used in my Croft, which currently is an Amperex one that's been fitted inside the preamp since I got it over 5 years ago, so I've just bought this NOS one to replace it:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...EOIBSA:GB:1123
May as well, eh? Can't do any harm!
Hi Marco and many thanks for interesting review .
I contacted Steve some time ago and he is sending me a pair of Mullard CV4004's, so will be interesting to see what happens them inside the preamp or phono stage. I also received a pair of black plate, triple mica RCA 5751's today, so plenty of tube rolling this weekend scheduled .
My Gear
Source components:
Garrard 401 in a solid birch plywood plinth / Trans-Fi Terminator T3Pro / ESCo modified Denon DL-103
Pioneer TX-9800 tuner
Amplification:
Art Audio Diavolo and Conductor, Pair of XTZ Sub Amp 1's, Nick G 'Dual Phono' phono stage
Loudspeakers:
Bastanis Mandala Atlas with 15" sealed woofers
Cables:
Analysis Plus: Big Silver Oval speaker cables and Silver Oval-in interconnects, Mark Grant DSP 2.5 Dual Screened power cables
Record cleaning
Nitty Gritty 1.5Fi MK II
Gentlemen,
I sense a possible bit of misunderstanding here. A lot of alternative valve designations and type numbers are bandied about as if they were synonymous. They are not.
This is best exemplified by the CV system of notation (Component & Valves; an UK government system introduced during WW II to catalogue the hundreds of valve types). Even if two valves had an identical electrode structure and geometry and hence identical electrical performance, some might be made to tighter tolerances, others might have be tested to more stringent levels, and yet others might be hand picked samples for use in critical areas (such as electronic telephone exchanges). All would have different CV numbers, and yet ostensibly be the same valve.
Then there are the valve designs that whilst not being identical are sufficiently similar that for most, less demanding, applications can be regarded as interchangeable.
I compiled an article on this for the Library: http://theartofsound.net/forum/showthread.php?t=3285 .
To give an example, consider the ECC83 discussed on this thread. The following is taken from charliehall.proboards.com
The 12AX7 was introduced by RCA in late 1946 or early 1947, along with the 12AU7. The original construction was the "long plate" style, identical to the 12AU7 plates. As was common at the time, popular designs were cross-licensed between manufacturers, and since the design was specified to the mechanical level, all American 12AX7s through the 1950s had the identical long-plate construction.
In the early 1950s, various European manufacturers started making their own versions of the 12AX7 (some under license from RCA), and called it the ECC83. The early versions had the RCA-style long plates, but I've seen some some exceptions, such as the Mullard "box-plate" version. Some European tubes started to be imported to America, most notably tubes from Mullard, Telefunken, and Philips (labeled Amperex for the American tube company that Philips bought around 1945). These European tubes were generally made to better standards than the American tubes and typically had lower noise and microphonics. As a result, high-fi vendors started using these tubes. To fight back, RCA and GE came out in 1961 with a re-designed 12AX7 called the 12AX7A that had lower noise and microphonics. They did this by using a shorter plate structure (with the grid pitch and distances adjusted to keep the same electrical specs) which allowed stiffer cathodes and grids. This became the American "short-plate" structure. It seems to be based on the design of the 12AY7 by GE around 1949, which started with a box-plate but by the early 1950s had moved to a short-plate structure. It may also be related to the ruggedized 5751 which came out around the same time and had the short-plate structure.
Interestingly, Sylvania, the other first-tier American Tube manufacturer, made only a long-plate 12AX7A that had more ribbing and reinforcement than the old long-plate. Based on curve-tracer measurements, the Sylvania 12AX7As have somewhat higher bias currents than the standard 12AX7, i.e. at a given negative bias, it draws more current.
As far as one can tell, the 7025 is identical to the RCA 12AX7A, but was made to cater to those who wanted an "industrial" type number. This was kind of a fad with hifi designers in the late 1950s. Maybe it was tested to tighter specs, but most 7025s are marked 7025/12AX7/12AX7A.
Philips (and hence Amperex and the other Philips companies such as Mullard and Valvo) adopted a short-plate design for the ECC83 around the same time as the American 12AX7A came out. With the exception of the box-plate Mullards, all the western European ECC83s were either long-plate or short-plate designs.
On the other side of the iron curtain, the USSR came up with a completely different design for the ECC83/12AX7 that one thinks originated with the 6N2P. There was a shield between the two sections, the plates were even shorter than the American/European short-plates, and the plates were spaced rather far from the grids. Again, the grid and cathode were adjusted to give the standard ECC83 characteristics. This design also showed up in China, and the bulk of newer tubes from Russia or China are of this design.
So, with the exception of the later Sylvania 12AX7As, all these tubes have essentially the same characteristics - the I vs V curves. What, then makes them sound different? One doesn't really know for sure. It can be suspected the cathode material and processing makes the biggest difference. There may be secondary emission effects that depend on the plate material. As far as we know, the getter shape doesn't affect the sound, but if the getter flash got into the wrong places, it could cause leakage and noise. The type of glass used might even be a factor, since different glasses have different resistivities which affects how long electrons "stick" to the inside of the bulb.
One thinks the best we can do is note which tubes sound like what in which system, note it, and then use the knowledge to chose your next tubes. In this sense it is more of a taxonomy than a predictive science.
Read more: http://charliehall.proboards.com/ind...#ixzz1GtpAPkS0
Going further afield we have for the ECC83:
Identical or near identical: 12AX7 12AXR
Different rating or performance but similar: 12AX7A 12AX7S 12AX7WA
5751 5751WA
6057 6681
6L13
7025 7382 7494 7729
3339 CK5751
CV 10319 CV4004 CV4017 CV492
CV8155 CV8222 CV8312
E2164 E83CC ECC803 ECC803S
ECC863
M8137 QB339
and the recently, short lived E813CC.
But were not finished - two different manufacturers can make valves having identical electrode geometry using identical materials, yet connoisseurs will often prefer one over another. Rather like two vineyards making wine from the same grape from the same harvest.
It's a bit of a minefield. Great fun for the aficionado, but I'll stick to 'sand'.
Thanks for the info, Barry - it's all good fun!
P.S However, you may wish to spell Aficionado properly
Done! I'm sure I checked with Google. But then you know speelying is not neccessarily my strong suit. Anyway, I'm half a bottle of red down at the moment. Well that's my excuse!
Have you noticed how much better Hamish's and André's spelling has become?
We should all strive for the highest standards here on AoS.
Regards
