Are you wiring the Decca correctly? Just trying to get to the bottom of this.
Will I did think about this before posting off the cartridge to John Wright, so I checked it and it looked fine into the 4 pin connector that it came with, it's colour coded so can't go wrong, I then read somewhere about using the 3 pin connector ( luckily I have that too ), that too is colour coded, so I swapped that in, still no difference, which was why I sent the cartridge to John.
I have a Rega Carbon MM cart that I bought to put on my Focus One TT upstairs, I've just put that on my 1210 TT and it sounds a little louder than the Decca from memory, but not greatly so, I can still go to max volume and ok it's a little distorted but it certainly isn't deafening by a long way. In fact a quick check with decibel meter app on phone gives me 76db at full volume.
I don't have an MC cart to test but I do know that before I sold the last of them last week I couldn't push the amp that far without killing something [emoji6]
I'll swap it over into the TQ phono input and report back.
Lol this just gets better and better, I now have the TT ( with mm cart ) into the MM phono input on the TQ Claymore Amp ( as pre ) and no difference, still low output.
THEN for a laugh I tried it into the MC input, now this should overload it somewhat right?
Well actually no it didn't, same volume just a little muddier sounding, what the FEK!
ok next move is to remove the EWA M-50 Power Amp from the equation and go integrated only, I think this might be the one thing I've NOT tried.
Getting rid of the Slagle is looking more and more likely to have been a big mistake, well here goes, back soon [emoji23]
I take it streaming is working with system so if 2 carts are same it looks like the phono stage or the connection in to amp; or the arm is faulty. try putting the other tq in as a test by itself. should tell you where problem is
Streaming fine.
What I don't get, is that the MC carts all sounded fine going TT - Vivant - TQ (Pre) - Power Amp.
The MM carts are the same no matter if I use the Vivant or the TQ built in stage, so it's not the stages, right?
It's not the TQ (Pre) as volume into Power Amp when using streaming as that's fine too?
So that should rule out the Power Amp mismatch too.
So can it be the arm? Why would it be ok for MC and not MM that's the bit I don't get if it is the arm at fault. Mind you the way things are going lately with my second buys it wouldn't bloody surprise me!
I'm away to try takingg the power amp out if the equation just to make sure it's not that.
Have you tried your spare tq.. the old one just as a trial. Not currently having a mc is stopping testing that again, but its at moment suggesting a fault in arm wiring or associated wiring re tt
Just had word that the HPD's should be despatched next Tuesday [emoji4]
