To adapt or not to adapt?
I am now the proud and delighted owner of a Chord Qutest. My conundrum is about the 2 sp/dif cables I use from my streamer and disc player which are both RCA - RCA. I now need BNC at the dac end. So the question is do I buy new digital cables RCA - BNC or use (a good quality) adaptor. My dealer says buy new cables and the manufacturer says I would never notice the difference, hence my puzzlement.
What does the panel do/think?
Oh yes, forgot to mention, my dealer did give me 2 Atlas adaptors free.
Quote:
Originally Posted by
I wouldn't get too hung up about the impedance of RCA connectors. True they aren't a constant impedance design and can never have an impedance greater than about 57 Ohm and in practice will lie between 30 - 40 Ohm, dependant on he material used to support the centre pin, but the impedance mismatch occurs over a short length electrically, so the electrical mismatch is not as bad as it might be. If true 75 Ohm BNCs were necessary, I'm sure both Sony and Philips would have specified their use.
RCA was chosen because it was cheap and accessible, not because it was right.
Signal reflections used to be much more of a problem, altering the transition points between samples, many DACs now reject the incoming clock anyway, I bet the Chord Qutest does...
My DAC uses no reclocking, and has a true 75R SPDIF front end, so I use BNC.
