Can I just ask as I notice in your signature you use a Croft RIAA R phono stage. What do you think of it ?
I thought it was brilliant and excellent value for money - much better than the standard RIAA. A very organic sound with lots of soul, texture and weight. Some would say perhaps not the most accurate on a test bench but I couldn't care less
I now use an Audio Note M3 phono which is better - but for considerable more ££. I could easily live with the Croft, but wanted to reduce the box count and was hoping to achieve synergy with the integrated AN phono and pre, and my AN IO 2 cartridge, rather than an Icon Audio pre, Croft phono and AN cart, so sold the pre and phono on
Incidentally Croft/Decca and croft/harbeth combinations have a cult following - and I also use Harbeth 40.1 speakers now
PS. My system has changed quite a bit from the one listed in my signature, but I'm unable to find the "edit" button to update it for some reason
I've now got another Zyx R100, low output one this time and it's sounding brilliant. I might even sell my Decca just to add some funds back into the pot.
Firebottle has offered to upgrade my Vivant even further as he says his latest tweak makes it even better.
So that'll be sent off this week.
Jamie,
I'm pleased that you're back in the Decca fold. :)
Charlie
Well I bought Jamie's Decca and after setting it up in my stax arm, which was fine with a super gold and some putty, I had a disappointing afternoon. Did a basic set up and had it tracking at 1.5grams, very thin and slightly harsh sound with no bass and worse still, was vocals were difficult to hear and fading as the track played. The whole sound was like an echo. I gave up and put the Shure ultra back and all was wonderful. Going to need some help. I met a guy yesterday who is very experienced with decca's and he suggested blue tak blobs until the best sound was found, then weigh it and replace with lead. Well I couldn't even start to think about blue tak as their wasn't anywhere to start. Cart and headshell weighs just over 25 grams, I have an extra counterweight that I fitted but there is room for adjustment if the headshell needs more mass. Any thoughts?
