Supreme Sound Audio discrete Op-amp upgrade
Hello guys! this is Charles from Supreme Sound Audio, a Burson audio subsidiary. We are an Australian based audio company.
It has been 10 years since we released the first generation of discrete opamp module, today after 5 generations of development the team has released the most beautiful sounding and most polished creation the V5 SS opamp.
http://www.ssaudio.com.au/wp-content...pamp-V5-S2.jpg
Link
Compared to the Gen 4 op-amp which already been called one of the best sounding by many audiophiles around the world, the V5 requires less voltage and current. Which translates to higher level of performance when applied to most audio applications.
We would like to invite fellow DIYer's and Audiophiles to try the new V5 opamp in their projects at no charge.
To apply please take the following steps:
**Please post an external view of your current gear
**Please post an top down internal photo of your current gear. (see example below)
**Stocked Op-amp model in the unit.
**Brand and model of the unit you plan to use.
http://cloudfront.bursonaudio.com/wp...5/01/step3.jpg
Round 1:
We will select a few guys from the thread to send the free sample. (We will also announce selected participants on this thread)
Once all the participants have posted their impressions and project photos, we will have the next rounds. That means, more people will be able to participate and try the new V5.
Power off and use an insulated removal tool
Hi
It would be advisable to advise to power the DAC or player down and leave for 5 mins , and use a proper insulated removal tool
as the image you show is connecting a non insulated screwdriver that is touching the negative voltage supply, pin 4 of a NE5534
with close to 15 volts , and likely touching other pins at the same time and shorting that voltage.
Maybe think about supplying a recognised IC removal tool, to your customers.
For those who choose to use a screwdriver, at least slip some suitable length heat-shrink
over the metal shaft, thereby insulating.
Cheers / Chris
