Advice on Michell tt
Decided to go fo one,
budget has an upper limit of 2.000€, so (I think) I have two options
1. get a new gyro se and fit the jelco 750d@denon 103R I already have
2. get a tecnodec and a tecnoarm ...
what do you think ?
*used, x-demo etc in nm/m condition will be nice too (just pm or mail me)
Quote:
Originally Posted by
Audio Al
Option one :)
I'd agree with that! :thumbsup:
option one , with a tecnoarm if you can
if I go with the gyro se @ jelco, tonearm upgrade will happen at a future time
Option One, no doubt. But........
.............. have you considered a used Orbe or Orbe SE. Michell TT's are incredibly robust and most are really well looked after. People do tend to hang on to them, but sometimes they crop up.
orbe is the end of the trip ...
but,
I doubt that I can find one that fits my budget ....
I have been looking michell's for the past months but havent spot one,
maybe in UK its easier
ok
got the point :)
gyro it is ...
I'm gonna make a last try searching for a used nm one or an orbe
and then I'm placing an order ...
The Orbe clamp kit is a very worthwhile upgrade for a Gyro. Save your shillings.
