https://scontent-lhr3-1.xx.fbcdn.net...9b&oe=57AE4DA5
Monitor audio are exhibiting at the High End Munich Show 5-8 May 2016, Hall 4, booth U04
http://www.mafocus.co.uk/content/log...eLogoWhite.jpg
***** Musicraft - Clearance + Special Offers list http://theartofsound.net/forum/showt...Special-Offers *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
https://scontent-lhr3-1.xx.fbcdn.net...68&oe=58C772EF
Monitor Audio Gold C350 centre speaker
http://ca2.monitoraudiocdn.com/produ...20150105154819
The Gold C350 centre speaker is a no-compromise centre channel solution for serious home theatre installations. Its three-way, four driver configuration mirrors that of the Gold 300, although the bass drivers are tuned to work in the Gold C350's sealed cabinet. Unsurprisingly the C350 is the perfect match for its floor-standing counterpart, producing frequencies from 40Hz to beyond 60 kHz. A neutral tonal balance and distortion-free sound give the C350 the ability to project crystal-clear dialogue and mid-range detail at any volume.
Monitor Audio. Design for sound.
http://ca2.monitoraudiocdn.com/techn...20150129104411
Monitor Audio Gold C350 centre speaker with Gold 300 main loudspeakers
Gold C350 Technology -
• C-CAM® (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60KHz
• Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
• New C-CAM RST® (Rigid Surface Technology) bass/mid-range driver
• Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
• Pureflow® silver internal cabling
• Selected premium quality wood veneer or high gloss lacquer finishes
• Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
• Invisible magnetic grille fixings provide a sleek visual effect.
Gold C350 Specification -
• System Format 3-Way
• Frequency Response 40 Hz - 60 kHz
• Sensitivity (1W@1M) 90 dB
• Nominal Impedance (ohms) 8
• Maximum S.P.L (dBA) 113.8
• Power Handling - R.M.S. (W) 200
• Recommended Amplifier Requirements (W) 100 - 200
• Bass Alignment Sealed Cabinet
• Crossover FrequencyL.F - M.F: 800 Hz, M.F - H.F: 2.3 kHz
• Drive Unit Complement 2 x 61/2" RST® bass/mid-range driver, 1 x 4" RST mid-range driver, 1 x C-CAM® H.F ribbon transducer
• Cabinet Dimensions (HxWxD) 254 x 581 x 333 mm, (10 x 227/8 x 131/8 inch)
• Complete Dimensions Inc Terminals (HxWxD) 254 x 581 x 360 mm, (10 x 227/8 x 143/16 inch)
• Weight (each) 19.6Kg (43lb 2oz)
Monitor Audio Gold C350 RRP £999 (Dark Walnut Real Wood Veneer, High Gloss White Lacquer and Piano Black Lacquer. RRP £1199 (Piano Ebony)
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
Thanks
Rick @ Musicraft
Hi-Fi Choice reviews Monitor Audio's Silver 8 loudspeakers
http://www.hifichoice.co.uk/news/art...und;1250/20489
http://ca2.monitoraudiocdn.com/produ...20140917115741
The Silver 8 has a new three-way design, optimised to deliver superb midrange focus and precision as well as extended bass. Effortless room-filling dynamics, even in larger spaces.
http://www.stereophile.com/content/m...-8-loudspeaker
Stereophile review Monitor Audio's Silver 8 speakers
Monitor Audio Silver 8 loudspeakers - AV Tech media Awards 2015/2015 winner for Best Floorstanding Speaker
Silver 8: "Bass is well articulated, midband is crisp yet smooth and treble is beautifully detailed. The Silver 8 delivers a rewarding performance with everything you throw at it, and is sublime at the price."
Monitor Audio Silver 8 Technology -
• Improved C-CAM® (Ceramic-Coated Aluminium/Magnesium) gold dome tweeter design with damped rear chamber and innovative dome venting technique for improved clarity and wider operating bandwidth.
• Specially developed 4” mid-range driver with ‘under-hung’ voice coil and motor system. The voice coil remains in the magnetic gap ensuring very low distortion - better damping and improved mid-range clarity.
• Dual 6” bass drivers featuring concave ‘dished’ C-CAM cone profile.
• RST® (Rigid Surface Technology) cone profile, for improved diaphragm rigidity and reduced distortion.
• Three-way configuration allows drivers to be optimised to deliver better overall performance.
• Improved cast polymer bass chassis design for better rigidity and reduced reflections.
• HiVe®II port technology delivers smoother airflow for better transient response and tighter bass.
• Single bolt through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling.
• Pureflow® Silver plated OFC copper internal cabling.
• High quality crossovers with premium grade polypropylene film capacitors.
• Available in selected premium quality wood veneers or high gloss finishes.
• Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity and low cabinet colouration.
• Invisible magnetic grille fixing provides clean visual styling when the grille is off.
• Terminal panel at floor level for easy cable connection.
Monitor Audio Silver 8 RRP - £1250/pair (Black Oak Real Wood Veneer, Natural Oak Real Wood Veneer, Rosenut Real Wood Veneer, Walnut Real Wood Veneer), £1375/pair (High Gloss Black Lacquer, High Gloss White Lacquer)
***** Musicraft website - Special Offers list http://ww.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
Monitor Audio will be exhibiting at the 2017 CES Show, Las Vegas, Nevada, USA. Venetian Tower - Suite 29-140 (January 5th - 8th)
Thanks
Rick @ Musicraft
The Absolute Sound reviews Monitor Audio's Gold 300 loudspeakers
http://www.theabsolutesound.com/arti...0-loudspeaker/
http://ca2.monitoraudiocdn.com/produ...20150105154622
Monitor Audio Gold 300 loudspeakers in Piano Ebony finish
Monitor Audio Ltd is a British owned and managed global specialist in hi-fi loudspeaker design. For over 40 years we've been incorporating stereo and surround sound systems and a range of sonically matched architectural speakers for ultra discreet high quality sound around the home and outside.
Whatever your taste and budget you'll discover a Monitor Audio speaker that answers your desire for great sound. Since hi-fi was in its infancy we've dedicated all our technical expertise, innovation and craftsmanship to the creation of world-class loudspeakers, which communicate the essence of our brand and reward the people who buy them. We want you to share and enjoy the blend of style, quality, performance and sophistication that makes Monitor Audio unique.
http://ca2.monitoraudiocdn.com/downl...0150821134145#
Hi-Fi News reviews Monitor Audio's Gold 300 loudspeakers
http://canadahifi.com/monitor-audio-...eakers-review/
Canada Hi-Fi reviews Monitor Audio's Gold 300 loudspeakers
http://ca2.monitoraudiocdn.com/produ...20150107130922
http://ca2.monitoraudiocdn.com/produ...20150107130919
http://ca2.monitoraudiocdn.com/produ...20150107130933
http://ca2.monitoraudiocdn.com/produ...20150107130925
http://ca2.monitoraudiocdn.com/produ...20150107130940
Standing at over a metre tall the Gold 300 is a majestic three-way floor-standing loudspeaker comprising twin 6.5" bass drivers, a single 4" mid-range driver and a high frequency ribbon transducer. With such an impressive complement of drivers, the Gold 300 has the power delivery and scale required to fill the largest rooms with jaw-dropping dynamics as well as the finest musical detail. Extending from below 30Hz to over 60kHz, its frequency range is among the widest available from any speaker, regardless of price.
• HiVe®II port technology for better transient response and tighter bass
Monitor Audio's Gold 300 loudspeakers RRP £3000/pair (Dark Walnut Real Wood Veneer, High Gloss White Lacquer and Piano Black Lacquer), £3600/pair (Piano Ebony)
Thanks
Rick @ Musicraft
Monitor Audio at the ISE show, RAI Amsterdam, Netherlands (7-10 February 2017)
https://scontent-lhr3-1.xx.fbcdn.net...fd&oe=5901AD46
https://scontent-lhr3-1.xx.fbcdn.net...36&oe=5904C2DD
https://scontent-lhr3-1.xx.fbcdn.net...ce&oe=590E37B6
Thanks
Rick @ Musicraft
Monitor audio will be exhibiting at Sound & Vision The Bristol Show (24th to 26th February) 2017 in Suite 1008 on the 10th Floor and in Room 208 on the 2nd Floor
Thanks
Rick @ Musicraft
Monitor Audio at Sound & Vision The Bristol Show (24th to 26th February) 2017
https://scontent-lht6-1.xx.fbcdn.net...76&oe=5930E34C
https://scontent-lht6-1.xx.fbcdn.net...5b&oe=59711DA5
Thanks
Rick @ Musicraft
https://scontent-lhr3-1.xx.fbcdn.net...9b&oe=5905098A
Monitor Audio's Silver 8 loudspeakers has received an "Exzellent" award from Stereo Magazine in Germany
http://ca2.monitoraudiocdn.com/downl...20170316093922
"The Silver 8 is a successful, dynamic all-rounder with distinct audiophile qualities, which will make a good impression in many living rooms and configurations. A mix of visual elegance, very good material and built quality, a non “brutal” straight-forwardness and an attractive price, which will ensure its success.”
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...sicraft-(Derby) *****
Thanks
Rick @ Musicraft
