Audio Innovations 500 'Reborn'
Well sort of.
This was my last project valve amp build. I thought you might like to see it?
I acquired a very sad AI 500 some time ago. An early one with the 'famed' 16 ohm tapped output transformers. I had had a rough life, and hard use. 3 of the EL34s were melted, the cathode resistor and wiring were burnt out as were the droppers...
http://i63.tinypic.com/68ep9f.jpg http://i66.tinypic.com/2rr1kj4.jpg
http://i66.tinypic.com/33vntqg.jpg http://i68.tinypic.com/200d6wi.jpg
My original intention was to rebuild it, but it was a, a mare to work on and b, too far gone. The other factor was its size, just too large for domestic harmony...
So as I had to strip it down and did not need the phono stage or all those inputs, just how compact could I make it?
http://i65.tinypic.com/o8f2tj.jpg http://i64.tinypic.com/2dj72xl.jpg
This big, just a touch smaller than a Stereo 20 chassis. Cutting the holes was very hard work with a Q-max cutter, the ally is 3 and 4mm thick!
http://i65.tinypic.com/14x0b5w.jpg http://i68.tinypic.com/a0duh2.jpg
But I was pleased with the result.
http://i63.tinypic.com/vhgjlt.jpg T.B.C
