Imgur is very easy and quick.
I've been using tinypic for years. Dead easy as long as you can cope with the adverts and occasional re-directs (well it is free).
http://tinypic.com/
You don't need to join or give details.
Thanks, Martin and Geoff. Both seem to operate is a simple, non-log-in way. I shall experiment when I've taken some up to date photos.
actually of all of them i find flikr the easiest to use , its fast and superbly simple and i am not the worlds greatest at IT
Not only can I work Flickr (big plus) but I enjoy their little messages whilst things are loading, like - consulting the magic donkey or loading gizmos etc.
I have started using Tapatalk whenever HC works well on the forums on it. I think you can access it on a pc as well.
