Possibly after a new amp for my dali epicon 2's and wonder what's available.
Budget is around £700 thanks. : )
the leema pulse is a lovely organic sounding amp that is very enjoyable . one here from well known shop frank harvey in coventry
https://www.ebay.co.uk/itm/Leema-Aco...gAAOSw3HJZiuW5
Hi Phil yip I had seen that one but wasn't sure about the looks do you think the Dali's need power as I thought I might try a tube amp but not sure with the pairing?
I'm using a Pulse SRA-160USB to run a pair of Dynaudio Audience 72s that I've just bought and they sound amazing, the amp cost me £60 SH or about £110 new delivered.
Alan Shaw, the Harbeth speaker designer, actually recommends this amp and similarly priced ones (Pioneer I think) for his speakers.
Thanks but I am really after something higher end to replace my arcam avr 600 as I am going back to two channel. I had a bladelius thor in the past and wish I had kept it if I am honest as it had loads of power on tap.
Fair enough, I've had some decent amps (stereo amps including a Sugden A21a and P21a and a Quad 34/306 combo) and the Pulse is up there with the best of them.
BTW, the speakers are a 4ohm load and need decent power and according to a mate of mine the Pulse circuit was designed around a copy of Quad amps circuits.
Those Epicon 2’s are some very refined speakers, and not cheap! I suspect that they will be very revealing of what you drive them with. Choose wisely, and don’t skimp.
If it were me? I’d get a 50 watt Krell! But that’s just me.
Hi Alex I will send you a pm regarding the arcam.
No one got a solid state amp they are looking to move on that will get the best from my Dali's thanks?
Hi, lve got a Musical Fidelity fitted with 4 AMR fuses and an after matket lead, lm wanting £800. Its in excellent condition
Sent from my D6503 using Tapatalk
