it is a shame . the earth terminal apparently can be used to bond the drive units back to ground to lessen the impact of rf interference . if shielded cables are used , this terminal can be used to connect to the shield apparently
so playing a number of other albums like pyramaxx which is sort of rocky electronica using the naim supernait 2 there is a real energy from these, crisp but not too crisp meaning at lower levels you can hear more. so annoying in the evenings to have to turn it down when you are sharing the room and not be able to hear the detail
the drums on mike oldfield sound very realistic , vocals realistic , not quite as good as the frugalhorn with the big msb amp but then the supernait cost about 13k less so that might explain that !!
