Would it be possible to build a clone of the Ongaku monoblocks?
A clone, yes, perfectly possible. The problem will be getting the exact output transformers.
I've just had a look at the cost of silver for the transformers :eek:, it would cost A LOT!
Yes, that is not going to be a cheap project!!
You can buy them from audionote uk for approx 20k :stalks:
You could certainly copy the circuit without using the very highly priced items. Won't sound the same as the original though..
Yes probably. A friend on another forum built an Ongaku clone.
