Yep, there's no option on the player so I presume that's why. Hmm, I'll see if I can get LM side loaded and see what happens then.
I’m not sure if it has been said as I have only scanned through quickly. You could use a raspberry pi to read the files and stream to the DAC. You could put one together for about £40 and use a dedicated sw such as Rune or Pidac which runs like a Logitech squeezbox and control it from a phone or tablet. Here’s a link to one blog
http://www.pimusicbox.com/
There are some real reasons why. Windows XP uses Kmixer that among other things resamples signals to 48kHz, and it is not bit perfect, Kmixer manages to mangle it, and it is also not a low level process, the audio signal gets no priority.
This is why it is so important to ensure that the system is outputting what’s fed to it, which is why it’s required to have lower level software like WASAPI or ASIO, or manufacturer drivers, to bypass the Windows mixer, ensure no resampling, and enjoy bit perfect files.
A recent Win10 update brought an obsolete (made obsolete by a Win7 to Win10 "upgrade") audio interface back to life for me.
The device, an EMU 0404USB, is a class 2 device, and Windows 10 now supports class 2 devices natively (ie Windows 10 is getting away from the Windows "proprietary drivers" way of doing things).
The Young DAC MkI is also a class 2 device - the chances are that it is now supported by Windows 10.
Would be interested to know if anyone can try it.
That it would.
In all the fiddling I've done recently Windows 10 sees the full capability of class 2 devices natively. The M2 Young dac uses the Hiface usb interface which Windows 10 supports.
As of ver. 1703 Windows 10 supports class 2 - current version is 1903.
There is some discussion on t'internet that the hiface driver (as updated for Windows 10) is better than the Windows 10 driver.
But I think Oli has moved onto an RPi solution since this thread.
That the devices are seen natively is a good thing.
If you were using Foobar to play music through a Young Dac MkI using USB you'd still need to use WASAPI to prioritise audio playback.
So part of the equation is a constant. You still need to use WASAPI to stop the machine from manipulating the data, which it will do if it's not stopped from doing so.
