yes its diluted. might need a bit more...the brush often soaks up a bit too. some old greasy records it can smear and puddle a bit, so you need to work at it a bit.
A very special offer on The Right One fluid HERE
im going to make my own using Triton x and distilled water.
this is a good read if you like to diy.
http://audiokarma.org/forums/index.p...-wrong.689430/
I ordered this a few times and I'm running out of the last bottle I purchased. I've looked at the eBay listing and assume it's no longer available. Does anyone know a good alternative or give me an idiots guide to mix Triton X and distilled water. The above link was far too complicated to follow!!
Help
Thanks
yep,its very gloopy so put 1 teaspoon in a jar and add 1 teaspoon of water and mix up,immersing the jar in warm water will help it mix,slowly add another teaspoon and mix again,keep going untill you have 1 teaspoon of triton to 9 of water,this is you stock solution.
to make the cleaner you use 5% of your stock to a litre of water,you can also add 5% ipa if you wish.
you can get the right one fluid from mcru he's selling it,although i think there might be a little price rise lol
He'll have paid for the rights to it though so doesn't seem so unreasonable when you consider that he has got to pay that off. I doubt much gets sold too since most people heavily into vinyl make their own and those who dabble don't tend to bother with anything more than a quick brush over before cuing. Niche market at best.
Thanks for the advice. I assume MCRU is Mains Cables R Us ?
I don't see it, unless it's the own branded stuff? If so, is this confirmed The Right One? The description is vague at best.
I looked on MCRU and couldn't see it
