On farnell website I just can't find the voltages I need in the suggested 15VA...
So options are these 2 TXs.
http://uk.farnell.com/multicomp/mcta...40v/dp/9530835
http://uk.farnell.com/multicomp/mcta...30v/dp/9530797
Any good?
The other solution I read somewhere else is to find a single transformer with different voltage on each secondary windings... Probably not an easy find though...
Yes no problem Francois, sorry I missed this thread before now.
I was only saying that you could use lower power trannies as you are proposing to use two for each voltage. 30VA (1st tx) + 30VA (2nd tx) = 60VA power rating.
Using larger rated trannies is perfectly OK :)
Alan
im trying to work out the same thing so there are 2 thicko's in the class :)
as i understand it i need 2 transformers 1 with a secondary output of 80v and 1 with 60v.
the website states,'The 30VA (2 x 15VA) types in the Mk2/kit version' . so i think this means 1 transformer with a primary of 15va,secondary 80v and 1 15va.secondary 60v.??
also how important is the primary value as the production norton psu uses 1 giant transformer rated at 1000VA
my head hurts!!
