Anyone got a cheap DC blocker going spare they can part with - or even lend me as I'm really just wanting to check something out.
Just looked online and the only commercially available one seems to be a piss-taking £250.
https://www.atlhifi.com/shop/fully-a...mbled-in-case/
I have two. Very good unit.
you could build one, very easy.....
http://theartofsound.net/forum/showt...rom-DC-Blocker
Ok, I’m confused? (It’s not that unusual), but why would you want a DC blocker? And where does it go in the signal chain? The ones in that URL look like they go in front of the power plug? And if you’ve got DC between the amp and speakers then you may have a major problem with the amp? Thanks for any help understanding this
Russell
Er, it's a mains issue. Plenty of info why needed in the links above or here
Ahem. :)
http://i68.tinypic.com/2natzsi.jpg
Sjostrom finished board. Not built into case yet, waiting for taller stand-offs, as I want to run the cable under the board.
