yup.. takes a mini tos
My 2014 Macbook Pro sounds better than any of the Windows laptops I've used, by a mile. A well set up Windows PC with a decent power supply then beats the Macbook, although only just. That's running Windows 7 and Foobar on the Macbook using Bootcamp, so its not an OS or software thing. Unfortunately I updated the version of OS-X recently and now it seems to get very hot running Windows 7, even though that partition didn't change at all...
The Macbook sounds excellent through both Optical and USB, though after my USB cable kept coming loose I stuck to Optical.
