Thanks - should I try switching the no7 switch on both panel of switches?
The bottom one, and looking at it again, man those switches are like optical illusions, yours is currently set for 40 dB gain, 47k ohm impedance, and 200pF.
First thing I would try is to move switch 7 down which will give 100pF.
MM cartridges can be very sensitive to capacitance ;)
Thank you - I'll try that when I get back - Colin
Just to confirm - sorry, do I try switching both "no 7" switches down? I presumed the panels are for left & right channels.
You should do both sides the same, yes.
According to that pic you have 40 db set at moment
Thank you - so I've just got to try switching no 7 down
In that pic it should go to left. Just one value on the other 2 off or to right. Same with resistance. 47k on other two off. Left is on and right is off
Thanks
