Put a dose of this when filling up last week and engines smoother at idle and a bit free-er when putting the foot down.
Fill up with V-Power which has cleaning agents but even then, this stuff improved things.
Your experience?
Your experience?
Yes the same. Saw it used on an older car on Top Gear, that measured hp before and after, added about 20hp I think, so it does work. Tempted to try a Terraclean.
Not really, there was a measured increase in horsepower in that segment of TG.
Mostly I suspect from the Redex cleaning the injectors.
On an older engine take the sparkplugs out, tip in a teaspoon of Redex, put the plugs back in, leave overnight. When you start the engine it will smoke a lot at first but quickly clear. Makes a big improvement as this frees up gummed piston rings and softens carbon build up. In the fuel it cleans fuel lines and injectors and carburettors, if you still have one lol.
Thanks guys, glad its not just me thsts noticed it.
