Why? Having not heard either it's just for interest.
Bit sweeping that no? - unless you are talking about just the 103S, there's lot more to a stylus assembly than a cantilever and a tip and overall implementation matters enormously and the SA may not be exactly the same beast.
Beyond that, I've heard a few cartridges sound superb with the Shibata stylus profile (not least the Miyajima Shilabe and of course the Miyajima Madake I'm running at the moment. Needs careful setting up but all cartridges do especially at this level.
I bought a 103SA once but it arrived with the stylus guard loose and the tip broken off so I didn't get to hear it :(
well i can tell you hand on heart,im not missing a fine line or shibata tip right now with this cartridge oli.
The SA has a spherical tip.
The Shibata stylus profile was designed for the replay of quadriphonic records (specifically CD-4) and whilst I have only heard one cartridge fitted with it, and so ought not to generalise, I didn't like what I heard: the treble was far too 'hot' and dominant. I much prefer 'fine line' or elliptical stylii and have several moving-coil cartridges fitted with them.
Yes. JVC's 'CD-4 Discrete' if I recall was one system (were there other record ones?). The fine Shibata stylus edge being needed to read the carrier signal modulations for quadrophonic rear infomation as well as the front stereo signal. I remember quad purposed Shibata stylus cartridges being slated for being too ruthless at the top end when playing regular steroe records.
The DL-103R does not lack detail and that also has a conical tip. Perhaps the same one.
