I want to do a bit of experimenting with speaker positioning and need a 5m pair of basic linear crystal oxygen free speaker cables to play with, bare ended is fine. Something flat is better. My Townshend Isoldas are only 3m!
Adey
Adey
Suggest a 10 Meter.. 10 Gauge!.. extension cord of the type tradesmen use for their power tools.
Cut in half, bare the wire ends.. and yer good to go.
Crystal Oxy wires (that are not merely a retrofitted Label) though... and it's best see your Banker And your Audiologist.. first.
G'luck
