Emporium I suspect :scratch:
I got my TDS buffer off them and it also came better than in the photo, again also unsure what happened with the other one.
It's arrived and out of the box but I cant do anything till I finish work in 3: hours.
It's big and I mean big. I'm a little confused about something - my isoldas are terminated in bananas (yuk) and all the blurb says the 75 doesn't doesn't accept them - but quickly checking I can insert the bananas into the back of the binding posts no problem - so it appears it does accept them.
I'm so nervous about putting in the valves and switching on....
Roll on home time.
Maybe changed them. used to be spades only as the holes were filled
Maybe modified.
The 75s I have seen have had screw terminals.
