Nothing very radical in the BBC modified version. This small board is it:
http://uploads.tapatalk-cdn.com/2017...24ce886db9.jpg
Adds function to the start fader (not sure what, as mine doesn't work. The fader isn't the standard type and has two sets of connections. Don't know if it's just a stereo slider as I haven't took it out yet.
If you're getting yours fixed, get new tactile switches fitted. They cost nothing really. Replacing them is a bit of a chore (27), but they make a WORLD OF DIFFERENCE to the feel of using it, being a lot, lot, lot more positive in action. The originals feel tired and shagged-out, by comparison. Really worth the trouble.
The two surface mount capacitors (1uF/33uF) on the motor-drive board will have failed, more than likely. A good chance the lasers will be OK.
Sent from my CUBOT_NOTE_S using Tapatalk
