More Heybrook TT2 questions - sweating the small stuff
Further to my Heybrook cartridge thread, I have some questions about getting the little (but important) things right....
+ What cartridge alignment tool should be used for the Rega RB300? Vinyl Engine has posted both a Rega template and a Heybrook protractor. Which is the correct one for the TT2?
+ What platter mat works best? It presently has the felt one. Is a cork or leather one an improvement?
+ Should I use a record weight? I have read that these may cause premature bearing wear on some tables. Is this true on the TT2? If not a weight, is there a clamp which tightens onto the spindle which you would recommend?
+ What bearing oil should I use? LP12 and Thorens owners seem to be using a light grade of full synthetic motor oil or spindle oil for air tools (Mobil brand, if I recall correctly).
+ Should I use different feet from the stock hard rubber ones? Vibrapods perhaps? Metal or wood spikes? Some type of levelling feet would be beneficial, at very least.
+ What support works best? I plan to place the deck inside a large wooden armoire which holds the rest of the system, and it will be sitting on a rigid shelf of 3/8" veneered particle board. Will I need additional isolation, such as a maple butcher block, marble/acrylic sheet, sandbox, or other type?
That's all I can think of for now. If anyone has other suggestions on getting the most from the TT2, I would be grateful to hear them.
I should be able to pick up the deck this weekend once I'm back home from my travels. Hopefully the shop will have a suitable cartridge on hand so I can start playing tunes straight away. Can't wait to hear it!
Thanks, and regards,
Svend
