Cheeky !!!! ;)
Cheeky !!!! ;)
Interesting thread...
I'm a big believer in centre speakers - mostly for when you want to sit at one end of the sofa and not the 'sweet spot'. A good one will add focus and solidity to the soundstage. I'm also a believer in setting the centre as 'small' even if it's quite capable in the bass department. The centre channel is the busiest channel in your average movie soundtrack. Hiving the bass off to the mains and/or sub leaves the centre (even a big one) and its power amp with more 'headroom' for want of a better term to handle the complexity of the signal.
My two cents anyway. I think the only exception is if you're running something really epic as your main stereo pair (801, DSP8000, other behemoths) where a centre may just sully the system and sound weedy by comparison.
I've gone one further and removed the sub, so 4.0 really...:eyebrows:
My main speakers (IPL S5TLs) go down to 23Hz, so I don't need any additional out of phase boom!
Removing the AV powered center, and pushing all 3 main channels through my stereo rig is a massive improvement, particularly with music videos...:)
All my AV processor does is drive my rear L & R rear surrounds, a set of old '91 Bose (OK I've admitted it ;)) AM5s, which are actually excellent for the rear surround job...honest!
My sub sits next to the hi fi ,and the TV and AV receiver ,on the other side .
I simply unplug the phono leads from one to the other ,depending on which I am using ,but its like spaghetti junction behind there !!
4 sets of speakers and a sub
I am sure if it was the living room ,I would have been evicted by now!!!
Also ,my sons room is above , so I have to exercise caution apparently:ner:
Fortunately the room is 20 x 40 ft , but seems to be filling up with hi fi boxes and second rate equipment:eek:
I get plenty enough slam from the IPL's mate! :)
And the rears have their own sub too (2.1), under the couch, so more than enough bass all round, as full frequency range is sent to all 4 speakers :cool:
Before the IPLs I used an old Yamaha sub in conjunction with my Mission 753s, they needed it...however with the IPLs in place the sub is rendered pointless IMHO
Absolutely, and that's cool. I was just saying that the addition of a sub doesn't have to result in "out of phase boom" :)
Certainly not.
As long as the sub is connected 'in phase' with the main speakers, the phase should be perfect. Also, the wavelength of low frequencies is so large that having the sub some distance away from the main speakers makes little difference.
That said. I've tried subs on occasion and did not get on with them.
Me neither, Geoff, as far as in 2-channel mode is concerned, but in the home-cinema system the Yamaha underpins and add gravitas very impressively to low frequencies. As such, I wouldn't be without it :)
