Well, tonight will signify my experimental move from 5 channel to two channel, I was flicking through my processor's instruction manual last night and it appears that it has two digital outputs which I didn't realise, although there are a million and one connections on the rear panel and I've never needed digital out before. So my plan is this:
1. Obtain a longer Toslink cable so I can move the DAC closer to the processor and still connect it to the Mac. I will need a 5 metre cable which is still well within the (alleged) 21 feet maximum limit as stated by Toshiba, the gain loss is 0.2dB per metre via Toslink but that's easily made up by the exceptionally high output from the DAC (5v). Not a problem really as I don't listen at high volumes.
2. Run a cable from the coaxial digital out from the processor into the coaxial input on the DAC thereby using the processor as a pre-amp (for AV only) and retaining the remote control volume. The output from the Mac will still go straight into the DAC and directly to the power amp.
3. Switch the PS3 to stereo output so that the processor only locks on to the stereo audio track.
4. Move the spare Target B10 rack out of the bedroom (the one I freed up by removing components) and back into the lounge, move the current rack over a bit to make room for the other one... basically move the whole sodding room around.
If I like it (and I'm sure I will) then it means I can remove the KEF centre, the Polk fronts and the Mission rears and the SE24 stands, more room for the two channel to breath and less visual clutter which as I get older starts to annoy me more and more. :)
Wish me luck!
