As the title says, what do you think I will be building over the Holiday time ?
A brand new spur for clean electric into your listening room?
That split board is enough to rewire a 3 bed house :scratch:
Good choice -I use a 30A Hager RCBO-MCB for the dedicated ring for my audio gear.
I have had some more parts delivered, and quite a few more parts to come :-)
I think it's going to be a balanced mains supply.
I have managed to play some more and fitted all the RCCB`s and MCB`s onto a fixing bracket and got the rear panel holes and cut outs done.
I have received the isolation transformers now so bit of positioning needed to allow for the transformers and the inrush limiters.
Once I am happy with the positioning a few more Rivnuts will be squeezed into place then the final wiring will be done.
It takes some shifting around, there`s over 30Kg for both transformers plus the MCB`s and RCCB`s, it all adds up. My poor back ....
